QUOTE(dlee6204 @ Mar 10 2012, 09:04 PM)
No! After disconnecting the electrical connections, you remove one mounting nut from under the car and remove the second nut from inside the engine bay. Done.
Thanks I read about the second nut and access to it in the engine bay. I dont see how I can get down to the nut on the back top of the starter ( the nut you can't get a socket on due to it having part of the starter mounting ear right up against the nut) from inside the engine. The tin is in the way. Do I remove it the tin or am I miising something. Is it a differet nut than what I see from under the car (from opposite the drivers side)???
