My 1972 2.0 will start when cold, its 50 F today, it will fire up and run pretty well, (as long as you keep it reved up) then in 2-3 minutes in coughs and dies. Then it will not start again but does try to fire up. If you let it set for 3-4 hours same thing, it will start, run for 2-3 minutes, dies and then will not start again. I can hear the fuel pump turn on each time. Suggestions??? Thanx
PS. when I try restarting, like 7-9 times, then it will not crank, just click. This time waiting for a 1/2 hours or so and it will crank again, but not start again untill you let it sit for at least 3-4 hours. ??? Thanx
