QUOTE(Haudiosolutions @ Mar 11 2012, 02:42 PM)
QUOTE(poorsche914 @ Mar 11 2012, 05:40 PM)
Tapered to the rear.
Grrrrr. Figures, Thanks
DON'T Cut it yet!When you pull these through you put tension on them. Even if you think you have no tension on them you do. And in 2 months from now they will apear to have shrunk.
It's a pain, but if you install then by putting in the outside edge in 1st and using a flat screwdriver to push the back side in, they will not apear to "shrink" later. Rubber has memory, and if there is any tension with vibration and time they will "shrink" back to the original size.
