Which of the two motor mount washers is correct? On my car, the right side has a big thick washer that rides up high on the motor mount plate. The other side just has regular washers, and this sits down low on the motor mount plate. What is the right setup?
Aaron Cox
Sep 18 2004, 10:40 PM
mine dont have allen bolts
jr91472
Sep 18 2004, 11:04 PM
is this a side shift setup? Are you referring to the inboard or outboard mounts?
Andyrew
Sep 18 2004, 11:47 PM
Mine has the one's on the right.. but not allen...
McMark
Sep 19 2004, 12:25 AM
Check out the PET.
I would, but I'm a free thinker.
914werke
Sep 19 2004, 12:22 PM
More infor needed
On my 73 Side Shift. It has 17mm bolts (i think). I bent two flat washers for "locking" tabs then dropped them threads down thru the mounts. Makes it a LOT easier when reinstalling a motor by yourself
