QUOTE(ndfrigi @ Mar 12 2012, 05:32 PM)
QUOTE(Sea Dragon 914 @ Mar 12 2012, 03:58 PM)
There is a small plate on the front of the driver's side door jam that has the paint code. Also, I believe there is a VIN number on the passenger front wheel well under the bonnet. I think there is also a chassis number on the passenger side in the rear trunk.
Thanks! So far here below are the vin number location i got:
1. Windshield - driver side (standard location)
> small plate at A-pillar-Windshield about 1/2 way up2. Driver door jam area
> L Rear Doorjamb low - VIN Sticker (Compliance Sticker) with VIN & Build Month/Yr. - often missing or painted over if ever repainted (use acetone on Q-tip & slow/patient work to remove over-spray if painted over)3. Front inside trunk passenger side close to fender
> No - it's stamped into TOP of RF inner wheelhouse inside F trunk (the factory originally left a small spot unpainted for it, but may be painted over later)4. Front inside trunk wall with the gas tank - a Plate tag
> NO - it's a small plate riveted on the inside face of the RF Headlight Box facing into the trunk (should be silver, but may have been painted over later)5. Driver door hinges area (small plate tag) but no vin number on it.
> This is usually referred to as the "Karmann Plate" on which the Chassis No. is stamped in the top box & color code on the lower box (originally silver with black background but may have been painted over by now)
> 2nd place for the Chassis No. to be stamped was the floor of the rear trunk back near the rear1/4of the floor at the center to right side - & it should match that on the plate in the LF door jamb (all VIN #s should match up too)How about on engine?
thanks again!
See inserted notes in your message above.If the VIN sticker on the LR door jamb is there, use the month/day to pull up a calendar for the year built (late 72 or early 73 for 73 MY). and the Chassis # at the LF door jamb, to translate your actual build day as follows:
WWD95##
WW is week # that year (count even Jan 1 as a week if one day)
D is day of work week M-F = 1-5
95 is Karmann Plant (96 is 95 + 1 for 100's of 914 built that day below)
## is number 914 built that day (add 100 if 96 above)
The color code # on the Karmann Plate below that can be found at the 914info button & the top of the page here, and you can see pix of actual 914s in the original factory colors at: p914.com
Last I heard the COA was $119 & I high likelihood that it will have errors. PM/email me if it does come back in error, & I'll help you get it corrected (it took me 3x & going to their Div. GM, but mine is right now & they shouldn't charge for corrections - but will make YOU do the work).
PCA discount on a COA was $20 AFAIK, but PCA is $50+/- per year, and you'll get 2 P-car magazines a month (Panorama Nat'l. + local Region/Chapter - Cypress could be OCR or GPX in Zone 8), & a bunch of P-car events, plus 20% off parts from dealers - so you'll make out ahead if you go that route IMHO - even if you never go to any events.
So if you want to check out the local OC PCA, drive your 914 down from Cypress to The Block in Orange (City Center Dr. exit North from 22) to the Krispy Kreme parking lot this Sat. at 8:30 - 10-ish am (every 3rd Sat) for our Porsches & Doughnuts outing (open to anyone who comes by BTW). You can meet PCA OCR folks & get a free Pandomonium magazine & member info., and you'll get attention from all the taildragger guys who remember when they had a 914!
PM/email me if you come down & I'll meet you over there, as I don't always make it.
FYI - if you also have a hole in the front trunk floor (or a patched closed floor now), then judging by your shorty center console, your 914 once had a dealer installed & Porsche+Audi authorized DPD AC unit (there was no factory air from Porsche back then). It would've looked like the pix below when installed....
Click to view attachment Click to view attachment
