So I'm down to my last quarter at Cal Poly Pomona and the last thing I have to do to get my degree is finish one class and complete a Senior design project. Therefore over the next 12 weeks I'll be building a Physical Vapor Deposition (PVD) machine which will be capable of creating a very high vacuum, heating & vaporizing aluminum, and depositing it as a super shiny/reflective coating on a substrate.
In order to recoup some of my project cost (I've spent almost $2k already, damn this school thing is expensive! ) I'm hoping to redo some fog light reflectors, front turn signal buckets, and maybe even some tail/brake/reverse light reflectors (Note: there may be a heat transfer issue on the rear reflectors since they're plastic, so I may not be able to coat them).
So the question for you guys:
Would you be interested in freshly coated reflectors for your lights and if so would $75-$100 for a reconditioned set seem reasonable? Keep in mind this will be dependent on being able to recreate a 98%-100% factory finish and that there will be a fair amount of material cost & prep time associated with each set of 2 reflectors done. Also, this will most likely have to be based on an "exchange" basis. To be honest I don't even know if I'll mess with this endevour yet or if I'll just sell the PVD machine when I'm done, so as of right now this is just a feeler.
Thanks in advance for the input!
Mike
