Since it was going to be 75 and sunny here today, I decided to drive her to work. She ran great this morning and fired right up this afternoon, but when I started it, I heard a brief "whirring" sound, which I thought might be my fuel pump. I have been told that they can sometimes be heard, but I can't really hear mine.
Anyway, she ran great all the way home until I was getting off the highway exit ramp on the last leg of my commute (25 miles). I was in the middle of three lanes, and as I was slowing, I could just tell something wasn't right. The whirring was back and it sounded as if it were coming from the front, but it also sounded as if it was somewhat associated with engine speed. It was hard to hear, since I have a bursch, and I was surrounded by 20 other running vehicles. I had the clutch in, so I put it in neutral and let it out. That didn't really make a difference.
I tried revving it a bit, and that is when she started sputtering and finally died. I could not get her to start again. Luckily, the ramp had a decent grade, so when the light changed, I was able to slowly coast down the ramp, across the road and safely off to the side.
I sat for a couple of minutes thinking about possible causes.
- fuel pump - explains the noise
- overheated - possibly, but doesn't explain the noise. However, I backdated my exhaust, so my heater cables are a little short leaving the valves open a bit, and it was blowing HOT today. Granted, it was 75 ambient, but it still felt warmer than normal.
- fuel pump relay - brand new, not likely
After sitting for a couple of minutes, she fired right up again, but when I started to drive off, she began to sputter again and I shut it down, called AAA.
It is a stock '75 1.8 with stock l-jet with about 130k miles. All maintenance items are new - cap, rotor, wires, pertronix, fuel lines, fuel filter, air filter, etc. Gas if fresh, as I just put in 5 gallons this afternoon. Fired right up when we pulled it off the flatbed, and I drove it into my garage. I had to wait an hour and half for the truck, so I am sure that it had cooled down quite a bit.
Any other ideas?
