QUOTE(ddcracingdave98 @ Mar 15 2012, 05:22 PM)
Hi,
I have worked on Type IV motor for other guys but never owned one. But, I just bought a '73 914 with a 2.0l. Has not run in 16 yrs, shifter is broken, brakes need work etc,etc. I don't care I always wanted a 914 and it's not rusted too bad. My pressing concern I'm looking for help with is the driver's door. Someone drilled the lock and now it won't open from the outside or inside. Anyone have any ideas about how I can get the door open? I can get in from the passenger side.
Thanks
Dave
DDC Racing
Belleville,MI
It sounds like both handles are broken. Remove the inside handle and pull the wire, that should open the door. You will probably find the wires pull tab broken off. Remove the door panel and reach real deep into the door and you'll find the inhex screw (use a 5mm? Ball Driver) holding the front of the exterior handle remove it and the nut behind the door edge and it will come off. You'll probably find a broken nylon slider. You'll need to post for a good interior handle as they are NLA and the nylon slider can be gotten fron Automobile Atlanta and others. The lock will have to be found used. Good luck.
