xsurfer
Mar 16 2012, 10:56 AM
The union between the hard pipe return tube and the rubber hose to the oil tank will not release. Is that thread a normal thread, clockwise rotation is tightening?
I have soaked it with pb blaster and sili kroil with no luck. My next step is to cut the rubber hose.
Any ideas to save cutting the hose?
Thanks
Gene
brant
Mar 16 2012, 11:00 AM
heat focused on the metal fittings
xsurfer
Mar 16 2012, 11:51 AM
QUOTE(brant @ Mar 16 2012, 10:00 AM)
My apologies, I tried heat. Stumped. I'm putting at least 50 lbs of torque on the nut.
Thanks
Gene
6freak
Mar 16 2012, 02:25 PM
try 55
...there tight
Jeffs9146
Mar 16 2012, 03:24 PM
I found that using two wrenches and squeezing them together would give me double leverage!
larryM
Mar 16 2012, 03:53 PM
big wrenches with long handle plus a third hand to keep the heat on
6freak
Mar 17 2012, 11:30 PM
did ya get it ??? i wouldnt use heat ..but thats just me
MikeC
xsurfer
Mar 20 2012, 08:49 AM
Nothing works so far. A friend recommended Sili Kroil used by aircraft mechanics, nothing so far.
I'll have to disconnect the hose at the tank to save the hose. I'll remove the tank.
Thanks
Gene
6freak
Mar 20 2012, 03:19 PM
bummer
