QUOTE(bondo @ Sep 21 2004, 11:58 PM)
I thought of a semi-plausible reason! The studs need to hold well, but are in magnesium... if they are cast into the case instead of threaded, with some sort of square head under the surface, you would NOT want to turn the stud. The helicoiled nuts would give another place for the nut to break loose without turning the stud, if the nut ever got stuck.
Nope...
I take the studs out of VW cases all the time, I have to put in longer studs for a mount bar I use on all hipo customers tranny's. The VW (bug) and 914 tranny are built basiclly the same way...just the shape, gears and etc are different.
