timothy_nd28
Mar 18 2012, 10:29 PM
Putting my car back together, noticed that the 14 pin wire harness that plugs into the relay board has been cut. I need that connector with 6-8" inches of that wire, so I can solder my wires to it.
Also, looking for the barrel nut that attaches to the throttle cable at the throttle body.
bdstone914
Mar 19 2012, 05:45 AM
PM sent
Bruce
IronHillRestorations
Mar 19 2012, 07:53 AM
If you can get about two feet it would be better. Stair step your splices so you don't end up with a huge wad in your harness.
timothy_nd28
Mar 19 2012, 08:38 AM
Thanks, excellent advice!
Drums66
Mar 19 2012, 11:40 AM
QUOTE(9146986 @ Mar 19 2012, 06:53 AM)
.......It would be better
falconfp2001
Mar 19 2012, 12:09 PM
I have an extra wiring harness you can have if you pay the shipping? It also has a working ECU attached.
Frank
GaroldShaffer
Mar 19 2012, 12:51 PM
QUOTE(falconfp2001 @ Mar 19 2012, 10:09 AM)
Frank
Frank,
If Tim passes on this I would like it, but only if Tim passes.
Thanks
timothy_nd28
Mar 19 2012, 01:00 PM
Take it Garold, I'm after the 14 pin connector thats part of the cars wiring harness, not the 12 pin connector attached to the. FI harness
falconfp2001
Mar 19 2012, 02:22 PM
QUOTE(tim_nd @ Mar 19 2012, 12:00 PM)
Oh, then you want this one
timothy_nd28
Mar 19 2012, 03:06 PM
Yep, that's the one
falconfp2001
Mar 19 2012, 11:36 PM
QUOTE(tim_nd @ Mar 19 2012, 02:06 PM)
Yep, that's the one
Don't think I have that one. sorry
markb
Mar 20 2012, 12:29 AM
I have a 14 pin, but it's only got about an inch of wires coming out of it.
naro914
Apr 4 2012, 04:16 PM
I may have one soon....
I am re-wiring Huey and found that I think I don't need the relay board at all....has a 3.2 with it's own ECU and wire harness. I think I only need 1 or two wires that go from the 14 pin to the 12 pin....if that...in which case I'll use weatherpak connectors and eliminate the relay board.
Then again, now that I htink of it...i should have all that from Papa Smurf already. Let me check....
JeffBowlsby
Apr 4 2012, 05:33 PM
Patrick MS sells the 14 pin new. PN 911 612 113 05 is for the one with male contacts...call them and they can supply female contacts if thats what you need.
timothy_nd28
Apr 4 2012, 07:09 PM
Thanks everyone, I purchased one from a world member. No longer in need for the 14 pin connector
Thanks everyone!
