QUOTE(mrbubblehead @ Mar 19 2012, 06:57 PM)
remember, you need 3 shims. no more no less.
Actually, that's not entirely true. Yes the VW manuals say "3", but it's not that important that you have 3. I've used 2 in certain circumstances when the trust surface on the flywheel has been trued where 3 won't fit with absolutely no issues. Porsche 356/912 motors only require 2. . .
The more shims you have, the less wear on the bearing so it's best to have 3, but 2 will do as long as the clearance is .003-.005".
