A collectors car. Immaculate condition. Guards Red(paint shines like a new car), Black Leather Sport Power Seats, Power Top w/ boot cover and tonneau cover, 91,310 miles. Third owner. All receipts. Limited slip differential and short shift kit as factory option. The following was done when I acquired the car at 88K miles - Motor: 90K service( fuel filter, Synthetic Oil change/filter, valve adjust, dist. cap, rotor, plugs, alternator belt) Replaced front crank seal, intermediate shaft cover seal, lower rocker shaft seals, two new hard oil lines from stat to tank, Beru plug wires, Steve Wong stock chip, OEM oil return tubes. Suspension: New Bilstein F/R shocks, Cambermeister Front Strut Brace, Turbo Tie Rods, Ralphe Booth 21mm Rear Wheel Spacers, Rear Sway Bar Bushings, Sway Bar Links/bushings, Elephant Racing Quick Change Spring Plates w/rubber bushings, Four Yokohama S-Drive tire, Euro Lower and Corner Balance. Misc: Four SS Brake Lines, New Lug Nuts all around, H4 Headlight upgrade(have H1 originals), New factory fog lenses, Paintless Dent Removal on entire car, Kenwood CD head unit, Four new Pioneer speakers for factory locations. Underside detailed.
Call 914-382-9702.
Many more pics of car which I can send.
- it's NOT ok to contact this poster with services or other commercial interests
View the full articleTHIS IS NOT A 914WORLD AD!
Do not reply to this thread! No one is listening!
Click on the "View the full article" link above to go to the actual Ad!
