Admins, if this don't go here please move to proper place
Alright I am stripping my 73 to build a production race car. I have the following stuff that needs to go but I am not sure how much of it is worth hasseling with.
Fully rebuilt rear trailing arms, new bearings, drilled and studded 4 lug hubs, semi flat repaint, Weltmeister race Poly bushings grooved with grease fittings, hand fitted to lathe polished pivot shafts.
Set of front Weltmeister poly bushings, hand grooved with grease fittings
Welmeister 23mm front sway bar
MSD 6 A box
Stock sound deadening pad for rear firewall
Stock passenger side foam? foot rest
stock back pad in great condition
stock basket weave door panels in decent condition
Front and rear chrome bumpers with crappy rubber
Stock gauges
AC console with 3 gauges
Stock pedal cluster, rebuilt with bronze bushings,
Plastic gas pedal from late model 911
2 RCI race buckets
Stable Energies Harness Bar
A nice peice of carpet from the rear trunk, fitted with trim around the edges. I liked the way it fit the rear trunk.
Stock gas tank, with all the stuff
Headlight motors and decent assmeblies
Custom modified 2.0 heat exchanger pipes, cross over pipe insert and header wrap
Fiberglass GT flares painted and drilled for bolt on application
Fiberglass front spoiler
Two 15x8 Diamond racing steel wheels, Black, drilled for 4x130 on a 5 inch back space
Some BMW 320 calipers, might have a two sets (not sure)
Four quarter inch wheel spacers
I haven't gotten a digital camera yet so I don't have pictures of any of this stuff. I just want to know if there is a mrket for most of this stuff before I go pricing it out and dealing with all the "I want it but..... (never hear from them again)"
