nebreitling
Sep 23 2004, 03:04 PM
don't want to wait 2 days for summit racing. i'm like a 3 year old; i need instant gratification.
is there a performance shop around the bay area who would carry a selection of universal filters?
tried all the flaps, nothing that'll work for me....
thx
nathan
ppickerell
Sep 23 2004, 03:43 PM
Vic Hubbards?
neo914-6
Sep 23 2004, 06:06 PM
Call Speed Merchant, San Jose
Brad Roberts
Sep 23 2004, 06:11 PM
Dont do it. Your asking for oil leaks. Your stock filter housing with a K+N works just fine.
B
Trekkor
Sep 23 2004, 06:19 PM
Nathan, I have a very fresh/used K&N filter from my 2.0.
You can have it for half price.
KT
nebreitling
Sep 23 2004, 06:32 PM
QUOTE(Brad Roberts @ Sep 23 2004, 04:11 PM)
really? your opinion definitely makes me think twice
why oil leaks?
i'm just trying to get colder air into the intake -- not necessarily more air. i've got abs piping and bends, brass barbs set into the abs with some silicone seleant and a heavy rubber coupling that clamps down around the intake. i was going to wrap the abs piping in some ricey-heat reflective stuff..
Brad Roberts
Sep 23 2004, 06:34 PM
If you dont pull a vaccuum on the crank case .. it will leak. The breather lines are 100% needed. Dyno pull after dyno pull have yielded NOTHING but more noise when using the "cone" filter. Dont get sucked in by the hype.
B
nebreitling
Sep 23 2004, 06:48 PM
ahhh, but i've included a large barb to hook up the oil/pcv line (just for that purpose).
can i try and snatch the pebble from your hand yet?
seriously, if i keep that line in the loop, am i kosher?
Trekkor
Sep 23 2004, 06:49 PM
Where would the leak appear?
As you know, I'm all hyped out.
It wouldn't happen to dump oil all over my clutch somehow, would it?
Reason I ask, clutch is slipping again.
Nathan, hold on filter...
KT
nebreitling
Sep 23 2004, 06:50 PM
QUOTE(Brad Roberts @ Sep 23 2004, 04:34 PM)
lmao
that was almost lost on me
Trekkor
Sep 23 2004, 06:57 PM
QUOTE(nebreitling @ Sep 23 2004, 05:48 PM)
First you have to walk without leaving the footprint...
KT
Cap'n Krusty
Sep 23 2004, 07:08 PM
Ahhhhhhhhhhhhh, another sucker following the advertizing hype that heralds products like fuel line magnets, Fram oil filters, and K&N air filters. Bigger holes allow more and larger dust particles by, and FAR less actual filter area than a factory type filter. Actually, the oil bath is even better than the paper, which is in turn better than the K&N. Do yourself a favor, stick with stock. In the long run, your engine will have a much better shot at a long life. The Cap'n
nebreitling
Sep 23 2004, 07:50 PM
ouch!
i don't disagree that those and other products are totally hyped -- but i'm just out to get colder air down the intake. i'm not one to question your experience, but i don't see what's hyped about cooler air.
of course, when i'm done, i'm gonna hook up 10 of those "tornados" in series. that ought to add about 50 hp, and let me get nearly 65miles per gallon.
maf914
Sep 24 2004, 08:28 AM
JmuRiz
Sep 24 2004, 08:52 AM
The only way to get colder air in the intake is to run a different style tube to get air from a location different from stock...like a snorkel to the outside or something.
