OK lets see how many hole I can shoot at this.
1. So if the 6 spring is more expensive (and yes it is) IT MUST BE BETTER
3. 6 spring disks could provide smooter engagement for "girlie men that can drive a standard"
4. For Manly men I just as well have a solid center and side step the clutch at 4500 RPM. 1st to 2nd gear and 2nd to 3rd as I am shooting through the cones.
5. Lets not even go there on the 19MM master cylinder. Good thing I got strng le3gs just to maybe equal the force I can generate with a 17MM (well maybe not)
6. Turbo Tie rods came from the other car. Rubber links were shot so it makes sense to put in what I had.
7. Bigger brakes sand wheels make more unsprung wieht so of course you need more brakes.
8. SSI l;ines came on the car no need to change them. Since I spend all my time in under and around my car I give them plenty of inspection attention.
The stronger adhesion just baffles me. same friction material same area sq. inch wise. Same pressure plate. By the way I am confident as much a hellion as I am on my car that 80 HP and itty bitty torque curve won't over power a stock clutch.
