Need 4 of the proper size bolts for an early steel bumper. Thanks, Mark
914itis
Mar 24 2012, 04:38 PM
front or rear?
bdstone914
Mar 24 2012, 05:17 PM
QUOTE(ppetion @ Mar 24 2012, 03:38 PM)
front or rear?
Front and rear bolt are the same and I think are a common 8 x 45mm. If you really want the correct original one I probably have some that are refinished.
Bruce
tod914
Mar 24 2012, 05:39 PM
The new ones available from Porsche, are black oxide. They should be cad/yellow zinc. Just so you don't waste you money ordering from them
Mar 24 2012, 06:34 PM
QUOTE(ppetion @ Mar 24 2012, 06:38 PM)
front or rear?
Front. Not looking for perfect, just the right ones.
(tried 2 hardware stores but nothing fit)
boxstr
Mar 24 2012, 08:49 PM
I like to use studs threaded on both ends. That way I can "easily" install the bumpers, front or rear, without any assistant. And using anti-seize to help avoid the nuts and the stud from getting frozen in place. Craig at CAMP
