rhodyguy
May 6 2003, 09:11 PM
any good auto body supply, not a parts store, should have it. after minor prep you can put it on with of those cheap plastic sprayers they sell at the dollar store. then even it out with a cheap foam brush. see a pattern here?
kevin
Gint
May 6 2003, 09:15 PM
I think I get it.
What's the consistency of it? Real thick or not so much? I mean, would it build up like bondo or is it not that thick?
EDIT:
Thanks BTW
rhodyguy
May 6 2003, 09:42 PM
thin enough for a squeeze bottle. you clean off the suface scale, wire wheel. DO NOT sand blast first. i cleaned with 3m degreaser, mar-hyde ( the directions are very specific and easy), self etching primer, multiple light coats of finnish. m-h does help fill minor imperfections in the metal. multiple coats with a sanding would finnish better. i was too impatient.
kevin
Lawrence
May 6 2003, 09:44 PM
Thank you for posting this. I want to do something to prep the bottom of my floorpan before I coat with POR-15. Something more substantial than just "Metal Prep", anyways.
-Rusty
rhodyguy
May 6 2003, 09:50 PM
i'm surprised nobody asked me what it cost. i think a quart was around $12 to $15. it goes along way. you always pour off into a glass or plastic container. i use my wifes little caning jars. if you keep it sealed it won't dry out. if you didn't see it, i posted pictures of how it looked this am in the engine pull thread.
kevin
Gint
May 6 2003, 09:56 PM
I did see it the other thread.
When it comes to fixing rust, saving a few $$$ isn't even an option for me. I really don't care what the cost is.
I appreciate you're posting the details on the stuff. Thanks!
John Kelly
May 7 2003, 07:29 AM
Rusty,
I would not use anything besides the metalprep under POR-15. Marhyde is a cheaper alternative to POR-15 or Corroless, and does not hold up as well over the long haul...but you get wehat you pay for if you're lucky (insert smily emoticon)
John www.ghiaspecialties.com
Dave Cawdrey
May 7 2003, 07:36 AM
I agree w/ John. The POR 15 system is unbeatable, IF used properly. The Marine Clean and Metal Ready quarts run 10 bucks each, give or take a buck for mark up.
Lawrence
May 7 2003, 05:08 PM
You guys are probably right - I just don't have any their Metal Ready (or Prep or whatever). (Forgot to order some more.) I had hoped to do some work this weekend.
-Rusty
EdwardBlume
May 7 2003, 08:33 PM
I used the Marhyde One Step stuff in my AX car and its held up very well. Because its fairly cheap, I really doused it (floorpan) and it ended up turning black and hard.
I then painted a few coats and its been fine.
Cheap is good sometimes when you need it.
Gint
May 7 2003, 09:29 PM
Follow-up question:
How do you remmove it if you have the need to do so?
Mark Henry
May 7 2003, 11:00 PM
QUOTE(Lawrence @ May 7 2003, 03:08 PM)
-Rusty
I've used Por-15 without the Marine Clean and Metal Ready before with no problems.
Wire brush the area wash with degreaser, then dish soap and lots of water to get rid of all traces of the degreaser. Let totally dry and paint, has worked good for me in the past.
Dave Cawdrey
May 7 2003, 11:10 PM
-Rusty
Rusty,
Shoot them an email. Ask for a distributor in your area. I somehow
forgot something, called, and found a distributor. Got my stuff the next day. Shipping was less than from POR 15. Well, duh?! It
IS closer to me...
EdwardBlume
May 7 2003, 11:48 PM
How do you remove it??? Wait a few years until it rusts again? Haven't made it there yet.
