Hate to break it to you Gerald & Tod, but that 165SR15 ZX would NOT have left the factory on a 2.0. The 2.0s were ALL (GA & GC) spec'd for 165HR15 due to their higher top speed capability than the 1.7 & 1.8 914s - which were the ones spec'd with SR rated tires.
It's more likely in both cases, your respective 914s' spares were replaced by the dealer before selling it - and if they were stealing the 2L Fuchs spare to sell & replacing them with steelies (as happened on mine) - why not shave a few more bucks off & only use the cheaper SR rated tires!!??
The other likely thing was that the SRs were put on by PO's on an early replacement - either to save a few bucks on a rarely used spare, or because HRs were NLA as of 79-80. For my last set of 4 tires in 1980 I had to settle for a set of 165SR15 Klebers, because everyone had stopped making & selling the 165HR15s!
Those stick-on VW & similar Porsche branded weights were available up through at least the mid-1980s - if you got your tires done at the dealerships, or if you ordered them as parts to give to your tire guys. I'd bet you can still get "branded" stick-on weights from VW &/or Porsche too (last time I checked parts dept. anyway), although they'd probably have an updated part no. stamped/cast in them.
So Guys, your SR tire/wheel could've been on the car when first sold, or changed later - but it wasn't what left the factory, unless it was an error (i.e.: similar to the "wrong" non-hub-centric Fuchs 2L & Mahle/Pedrini wheels that went out on some early 73's up through Dec 72, which resulted in recalls by Porsche+Audi to check all 73 alloys for -01 part no. & hub-centric machining, or replace).
PS - it certainly looks like a never or very minimally used spare tire!
Cheers!
Tom
