with the above, but if you've got the GA motor already - or don't mind having a non-original 75-76 MY GC 2.0 (easily returned to stock if you save the parts) -
Then I'd highly recommend that you go with the 73-74 non-cat 2.0 exhaust system (SS HE's are best bet) & OE Banana or another Bursch, Triad, etc. muffler.
It will let the motor "breathe" better & thereby produce more HP along the lines of the 95 HP of the 73-74 2.0s.
I was surprised with our 88 Westy's 2.1L waterboxer, at how much more power it produced over the past 6-9 months, with the old original CAT insides disintegrated out & acting as a thru pipe (but we've just replaced it & re-smogged, so we're back to "normal" now).
So any 75-76 1.8 or 2.0 will perform better with the early 73-74 2.0 exhaust & no CAT, but you're in Poway CA so if it's a 76 you're stuck with the OE system & CAT & bi-annual smog tests!
