QUOTE(tadink @ Mar 30 2012, 09:02 AM)
QUOTE(falconfp2001 @ Mar 30 2012, 12:23 AM)
Yes. There are two types, 3 pin and a 4 pin. Which do you have?
ahhh, now I understand your question - and the answer: beats the hell out of me! sigh, I'll have to go look now that it is light out - hold the phone.
td
No problem. It depends on the year of the engine. Youmay find a different year ECU and engine in an earlier car. The 70 to 72 1.7L had a three pin and then they changed it in 73 and later to a four pin.
The 2.0L had a five pin I believe. I have one of each 1.7 TPS and the TBs with them that I won't be using anytime soon. You should look at your PCB inside the TPS and compare it so this. If you see tracks worn into the PCB then you may want to consider replacing the board. They sell new ones at AutoAtlanta. Or just use the best TPS you can find. 1.7 are plentiful and may be 20.00 bucks. You can have mine for postage if you want.
