c12croft
Mar 28 2012, 10:39 PM
The caption lines essentially cover it all.
Can the steering wheels of the sixes fit the fours and vice versa?
Specifically, can the wheels shown as advertised for one also fit the other?
Although I've not verified it yet in any tech manual, I've got the sense that the answer is no, just based on reading the tech info found in eBay ads.
Can anyone here confirm my suspicion here or not?
note: extra credit given to those who bother to answer and include a description of the physical differences
Thanks
Jeffs9146
Mar 28 2012, 11:06 PM
I don't think so! Different spline count I think!
pete000
Mar 28 2012, 11:20 PM
The early 911 guys all want the 914-6 steering wheels because they are smaller in diameter than the 911 wheel. I imagine the splines are the same for the 911?
They say the 914-4 will not work on the 911 without modification.
This and their rareity might be whey the six wheels are so expensive.
TravisNeff
Mar 28 2012, 11:22 PM
Then how do I see some guys get a SC or a Carerra wheel on their 914 - without changing the steering linkage.... :hmm:
pete000
Mar 28 2012, 11:39 PM
QUOTE(Travis Neff @ Mar 28 2012, 10:22 PM)
I think the 924 and 944 share the VW spline and could possibly work in the 914-4 and could be mistaken for a 911 wheel.
I have a 944 steering wheel in my VW Vanagon.
Jeffs9146
Mar 28 2012, 11:47 PM
I know that I had a later (74) steering wheel that would not fit my 6!
carr914
Mar 29 2012, 05:42 AM
QUOTE(pete000 @ Mar 29 2012, 01:20 AM)
The 914-6 Leather Wheel is the Same wheel Porsche put in the 73 Carrera RS. So peeps that are doing a RS Clone want our wheels.
Yes the spline count is different between the 4 & 6
ClayPerrine
Mar 29 2012, 06:05 AM
Early 911 steering wheels will fit a 914/4. When the 911 went to the SC, the steering column changed, and so did the spline count on the wheel.
I know, I fit a 914/4 wheel to an early 911 (68) column in my car. The only difference is the adapter on the back of the 914 wheel that adapts to the VW column used in the 914/4.
And if anyone wants to argue, I will make a video of me taking the steering wheel off of my wife's 74 914/4 and putting it on my 68 912 chassis.
Jeffs9146
Mar 29 2012, 08:13 AM
The question was
So the answer is NO, the spline count is different!
brant
Mar 29 2012, 08:49 AM
I Put a carrera wheel into my teener
I had to have a shaft cut down, machined, and re-splined...
not an easy change by any means.. not bolt on
ClayPerrine
Mar 29 2012, 11:46 AM
QUOTE(Jeffs9146 @ Mar 29 2012, 09:13 AM)
The question was
Then how did I do it without machining anything?
Mar 29 2012, 01:59 PM
QUOTE(ClayPerrine @ Mar 29 2012, 10:46 AM)
The question was
You didn't. You put a /4 wheel in a early 911.
That's not the same as interchanging a 914/4 wheel with a 914/6 wheel. Which you can't. Because they have different splines.
Lightweight_911
Mar 31 2012, 06:17 AM
Sorry but there's some mis-information on this thread.
All 914 steering wheels - 4 & 6 cylinder versions - have the same number (& diameter) of splines !
Any 914 wheel can be fitted to a pre-'74 911 after removal of the plastic 'spacer' on the rear (held on with 4 screws).
I have bought/sold over 200 914/4 & 914/6 steering wheels so am talking from personal experience.
There are some (subtle) differences between early 914/4, later ('72-on) 914/4 & 914/6 s/wheels but not in regards to the number/diameter of the splines.
a914622
Mar 31 2012, 08:45 AM
I have just put the 71 911 wheel and the 85 911 wheel on my 75 914-4 column, I dont have a -6 wheel so i cant try. I know the hub lenth is longer and the 911 wheel feels to close to the driver. (for me)
The 924/944 have a smaller dia on the splines, I know that because the fit the vanagons and the Mk1 rabbits! The plactic ring that stops the turn signal is different but you can unbolt the vw and bolt it to the porsche no problem
jcl
jmill
Mar 31 2012, 11:22 AM
QUOTE(Lightweight_911 @ Mar 31 2012, 07:17 AM)
If this is true then why does this guy think recovered 6 wheels are gold plated?
http://forums.pelicanparts.com/porsche-911...ring-wheel.html
Jeffs9146
Mar 31 2012, 11:54 AM
QUOTE(jmill @ Mar 31 2012, 10:22 AM)
http://forums.pelicanparts.com/porsche-911...ring-wheel.html Mis information after mis information here!!
The 6 original stearing wheel will not fit a 4 stearing colomn! I have tried it! The splines don't match. You can mix and match an early 4 with a late 4 and some 911's!
Jeffs9146
Part # 914-347-806-10
The 6 original stearing wheel will not fit a 4 stearing colomn unless the very early 70's used the same colomn! I have tried it with a 74-4! The splines don't match. You can mix and match an early 4 with a late 4 and some 911's!
racerx9146
Mar 31 2012, 11:58 AM
I agree.... That my experience.. Early 914 wheel on my 914-6 column...
QUOTE(Lightweight_911 @ Mar 31 2012, 05:17 AM)
Mar 31 2012, 01:15 PM
I disagree ...
brant
Apr 1 2012, 09:04 AM
I don't have a PET any longer
can someone look and see if the part numbers changed from the -6 to the -4
Jeffs9146
Apr 1 2012, 09:34 AM
70/71 914-6 Part #'s
914.347.803.10 Hard Rubber Steering Wheel
914.347.806.10 Leather Steering Wheel
72 914-6 Part #
914.347.805.11 Leather Steering Wheel
70/71 914-4 Part #'s
914.347.804.10 Hard Rubber Steering Wheel
914.347.805.10 Leather Steering Wheel
914.347.090.10 Hard Rubber with Porsche Signal Key for USA only
914.347.091.10 Leather Steering Wheel with Porsche Signal Key for USA only
72 and Later 914-4 Part #'s
914.347.804.11 Hard Rubber Stearing Wheel
914.347.805.11 Leather Stearing Wheel
914.347.809.00 Steering Wheel with Foamed Rim
In conclusion, it looks like the 72 914-6 is interchangable with the later cars because it has the ignition switch steering colomn from the later car but the 70 914-6 is a different part number completly!
Lightweight_911
Apr 1 2012, 10:11 AM
Sorry but I have had every version of 914/4 & 914/6 steering wheel & all of them fit on an early (pre-'74) 911 column.
I'll repeat again, the number/diameter of splines on all 914/4 & 914/6 - plus '65-'74 911/912 models is the same !
For any of you doubters, try this - take any 91/4 steering wheel, remove the turnsignal cancelling ring (3 screws), remove the large black plastic 'spacer' (4 screws) & then slide the wheel onto your 914/6 steering column ...
The main differences between an early ('70/'71) 914/4 wheel & a later ('72-on) 914/4 wheel is that the latter has a recessed area in the centre where the retaining nut goes whereas on the earlier 914/4 (& 914/6) wheels it's flat.
The main difference between any 914/4 wheel & a 914/6 wheel is that the 4-cylinder version has the plastic 'spacer' on the back & a smaller diameter turnsignal cancelling ring.
pete000
Apr 1 2012, 10:21 AM
This must be why I sold a bunch of 914-4 steering wheels to 911 guys lately. They were all going to have them recovered to the thicker grip and put them in their early 911s.
I did have one guy tell me that only the 914-6 wheel would work in a early 911.
There is a company doing this and modifying the turn ring. They are not cheap!
Jeffs9146
Apr 1 2012, 10:22 AM
It looks like we will have to agree to disagree because I have tried it!
Lightweight_911
Apr 1 2012, 10:41 AM
QUOTE(pete000 @ Apr 1 2012, 05:21 PM)
The only modification needed on a 914/4 wheel when fitting it to an early 911 is to drill/tap/countersink 2 holes on the rear to allow fitment of the 911 turnsignal cancelling ring.
This modification is not needed for a 914/6 wheel as it already uses the 911 cancelling ring.
Michael N
Apr 1 2012, 12:42 PM
QUOTE(SirAndy @ Mar 31 2012, 11:15 AM)
I disagree ...
I am going to have to agree with Lightweight on this one. I had just picked up a wheel from pick and pull this week. My thought is that I would use it on my car while I sent another one out to Dallas Custom Steering Wheels for the double leather (Extra thick grip)wrap. This thread had me worried for a minute.
Car is an 1970 original 914/6.
Here is my investigation from this morning:
Click to view attachmentNote the recess center.
Click to view attachmentClick to view attachmentWith the hub unscrewed. One minute process.
Click to view attachmentClick to view attachmentOn the /6
Click to view attachmentThe early wheels have the countersink for the 914/6 turn signal cancel ring.
Click to view attachmentHope this helps.
Jeffs9146
Apr 1 2012, 02:43 PM
Not one of those part numbers is from a 70 914-6!
Michael N
Apr 1 2012, 02:50 PM
QUOTE(Jeffs9146 @ Apr 1 2012, 12:43 PM)
Yet they both fit on my original factory 1970 914-6!!
ClayPerrine
Apr 2 2012, 04:56 PM
ClayPerrine
Apr 4 2012, 09:41 PM
No additional rebuttals?
Bueller?
Bueller?
db9146
Apr 14 2015, 09:48 PM
Ahhhh, I was looking for an answer to this burning question and no videos!!!!!
Apr 15 2015, 05:09 AM
QUOTE(db9146 @ Apr 14 2015, 11:48 PM)
Early 4 wheels and 6 wheels are the same. They just use different parts to cancel the turn signal. Late 4 wheels are the same spline but use a different plastic hub. Spline count on all 4 wheels are the same as well as early 911 wheels. early 4 and 70-71 6 wheels bolt onto a 911. if the model number ends in 10, its early, if it ends in 11, its late. late 4 wheels require a small mod to fit on early 911 but no mod to fit early 914-4.
914-6 uses the same cancel ring as early 911
rhodyguy
Apr 15 2015, 09:25 AM
the cup on the rear of the wheel is dependent on the column the wheel is being installed on. one is thicker than the other.
motorvated
Sep 9 2015, 07:15 PM
QUOTE(rhodyguy @ Apr 15 2015, 09:25 AM)
I recently bought a Dino wheel with a hub adapter from the classifieds that was supposed to fit my '72 914/4, but it does not. It appears that the spline count is different. Stock wheel fits OK, adapter does not fit. Does anyone have the actual spline count of a '72 914/4 steering column, and a good way to accurately count the splines other than being really careful?
motorvated
Sep 9 2015, 07:39 PM
QUOTE(motorvated @ Sep 9 2015, 07:15 PM)
Just finished carefully counting splines on my '72 914/4 steering column and counted 40. Counted the splines on my Dino hub adapter and it looks like there are 41. Is it possible that the early 914/4, 914/6, and early 911 have steering columns with a spline count of 41, and the '72 and later 914/4 has a spline count of 40? Hate to beat a dead horse here, but I'm trying to figure out how to mount this new Dino wheel.
Cairo94507
Sep 9 2015, 07:57 PM
I bought an early 4 steering wheel for my Six. I took the plastic ring off the back of the wheel and I bolted it up to my Six with no problem at all. All Scotty will have to do we need install the complete wheel on the car, is drill and counter sink the two holes on the back of the steering wheel. So for whatever that is worth.
914werke
Oct 19 2016, 01:00 PM
This thread should be moved to the classic thread Forum.
The only detail that seems to be excluded here is the Diameter of the wheels in question.
My understanding is ALL 914's are 380mm dia. wheels & that the early 911 wheel is a LARGER dia. ?
And, that is the other reason 911 guys are seeking 914 wheels for swap?
Oct 19 2016, 03:25 PM
QUOTE(motorvated @ Sep 9 2015, 09:39 PM)
All the 914 wheels and all the early 911 wheels have the same number of splines. They interchange. I guarantee it. - I have all those cars in my shop so I can prove it.
QUOTE(rdauenhauer @ Oct 19 2016, 03:00 PM)
Yes
pete000
Oct 19 2016, 03:34 PM
rudedude
Oct 19 2016, 08:29 PM
early 911 wheels were generally 400mm
914werke
Oct 19 2016, 10:09 PM
QUOTE(rudedude @ Oct 19 2016, 07:29 PM)
Thank You
Oct 20 2016, 03:39 AM
QUOTE(rdauenhauer @ Oct 20 2016, 12:09 AM)
Thank You
Or 420mm
Mike Fitton
Apr 22 2020, 05:43 PM
Has anyone seen an early steering wheel with part # 914.347.088.10? This one is dated 9/69 had a leather cover but it has been removed also has the "VW" logo instead of the "P" logo, flat front hub and countersunk holes for cancel ring.
Click to view attachment Click to view attachment
Apr 22 2020, 05:56 PM
QUOTE(Mike Fitton @ Apr 22 2020, 07:43 PM)
Click to view attachment Click to view attachmentYes, I have one with leather and also have a 914.347.087.10 with a plastic rim. Seems to be an early version of the 804 & 805 wheel.
@Mike Fitton
