QUOTE(spare time toys @ Sep 29 2004, 03:40 PM)
I thought you would not have the slosh with a foam filled cell. ...on a normal car your exhaust is close to the gas tank so that is a wash.
you seem determined to do it, so go for it. it's your car, do what you want.
the foam helps with slosh, i'm sure, but MOSTLY it's there to prevent a place for vapor to accumulate. liquid fuel will burn but it won't explode; vapor will explode.
it's not quite a wash - those cars are pretty much stuck with it, i don't know why you'd go out of your way to store fuel in a hot location, but try it if you want. a front engine car has many feet between its hot engine and its hot transmission, but they are in front of and under a 914's back trunk.
just remember 140F. plus or minus a little, that's the boiling point of gasoline.
