QUOTE(Al Meredith @ Apr 5 2012, 06:19 AM)
There are 3 different pistons (4 if you count bus) (5 if you count the high compression 1.8L) two rod types (3 if you count bus) and 2 cranks . What combo are you interested .
As mentioned in the title, I want a stroked crank. Preferably 78mm. This requires pistons with lower compression height and matched rods. All this to avoid insane shims under the cylinders.
