QUOTE(Rderow @ Apr 5 2012, 08:27 AM)
I have a 1974 914 that I recently replaced all the bushings in the linkage on and had tried to adjust the clutch and stop but it is grinding when i put it in first ever so often and in reverse almost every time unless the stars align. I have had two mechanics look at it and they said it is not the clutch itself but maybe it needs another adjustment? any ideas? Someone said it could be the clutch tunnel broken off in the center tunnel but it doesn't feel like it is. There is def movement when i push the clutch in on the shifter. Thoughts?
thanks guys!!! I will try the suggested...stay tuned!
