Since my heads are off and I am SLOWLY converting my 2056 to megasquirt, I am rethinking some of my stuff.
What is the ideal compression ratio for my motor.
I am willing to run 93 octane fuel - I run it now.
I have a 9530 Raby cam and valve gear.
2056cc
spark is going to be electronically controlled (maybe EDIS, maybe something else)
I was thinking of dropping compression to 9.0 or maybe even 8.7.
I want more compression then stock, but I want cooler head temps then I currently get (the engine has always run warm at the heads, and I can never use 5th on the freeway to keep temps down). My normal operating temps tend to be 360-380 and I'd like to back them down ~10 to 15 degrees. Head temps were measured on Cyl 3 with a compensated Dakota Digital CHT gauge.
When I built the engine, I just set the deck height to .040 and figured out the CR later. I know better now, and am at a great point to correct it.
Zach
