QUOTE(vsg914 @ Apr 7 2012, 06:39 AM)
Rgalla, I have never heard this method, and I am old school and old. Please explain this a little further.
First, to determine that no original marks are being overlooked do the following.
Bring #1 up to top of stroke, determine that there is clearance at both rockers. Put a screwdriver into spark plug hole to verify top of stroke. Check to see if ign. rotor is pointed at notch on rim of dizzy. Ignore the dizzy if it is not.
Look through window at rear of engine. The flywheel can be seen through the tin and an opening at top of transaxle. Is there a large notch there ? If yes line it up with crankcase seam and look for a mark on the fan, it is very easy to overlook if it is a bus fan and is marked only at the rear of the timing hole. If there is nothing there mark fan with bright colored paint for TDC,
Still nothing ?
If no marks are found a tool to determine TDC can be fabricated or purchased.
This is how it works.
Remove all spark plugs, bring engine to top of compression stroke #1 cyl. Move piston off top of stroke slightly. Install piston stop in spark plug hole. Bring piston back up stroke till it touches stop. Mark flywheel at this point. Now rotate engine in opposite direction until it touches the stop again . Mark fan or flywheel at this position.
Measure the distance between your two marks . Half way between those marks is TDC This is not an easy task on an installed 914 engine.
When TDC is known and timing spec is known a timing light with adjustable advance can be used to set timing.
