i just put the 2.0 d-jet harness on and i still have one red wire comming off the aar. Does this thing go to ground? or does it need 12v from somewhere. I cant figure it out.
1973 2.0 w/D-jet
falconfp2001
Apr 7 2012, 08:43 PM
QUOTE(jsayre914 @ Apr 7 2012, 07:38 PM)
1973 2.0 w/D-jet
It gets 12v from your ignition cable 12 pin
Spoke
Apr 7 2012, 08:47 PM
The schematic in my repair manual shows it connecting to pin 12 of the 12-pin connector on the relay board. The 12V power for pin 12 comes from the FI fuel pump relay on the relay board.
Do you have a wire on pin 12 on the pigtail to the engine?
falconfp2001
Apr 7 2012, 10:15 PM
Int is also a white wire. with a female spade on the end. You need the male to male plastic spade connector for these two wires.
