QUOTE(mrholland2 @ Apr 8 2012, 02:03 PM)
Was working fine. . had been up over 2/4 mark, descended as I drove a bunch. . .filled the tank at maybe 1/3 below the 2/4 mark. . now it will not go above the 2/4 mark at all, but does go clear to E when the car is off.
Suggestions?
(I'm have a gauge-bad weekend!!)
I bought a 914 that had been sitting for 19 years. The seller stated that the gas gauge worked. Actually at best it only registered between empty and 1/2 full. Most of the things on the car steadily showed up as emerging problems, but the gas sender eventually fixed itself. After a few tank fulls its range steadily increased until it now actually works! I don't know why, but they like to hang up at 1/2 full. I have subsequently boiled out the tank and derusted the system, but I have the original sender. I wiped it down with a cloth, but it was working by the time I took it out, so I don't know if it helped to clean it.
They are right, it isn't hard to replace, or to get out and see how bad it is. Good luck.
