I experienced a problem with starting the motor that I am baffled about. When releasing the key from START to ON the engine continues to turn over. Fortunately my friend was there to disconnect the battery quickly.
A little background on this...that day I upgraded my fuse panel to the LED fuse panel and had a small meltdown related to the backstrap of the fuse panel grounding out on the small isolator power junction (all red wires screwed on isolator) mounted to the side panel just left of the fuse panel. After repairing that and relocating the isolator by just removing, taping it up and stuffing it, I remounted the fuse panel and had power to everything properly. But when I went to start it (didn't start first try due to cold start) it kept cranking when the key was released from START to ON.
Now I suspect that a relay or solenoid has possibly taken a hit with the above mentioned event.
Questions...
1- If the starter solenoid is fried it wouldn't start right? It does start.
2-Is it possible that the drive pinion, mesh and starter ring are sticking? But wouldn't that grind after running? There is no grinding.
3-Is it possible its in the igntion switch?
Thanks for any help or experiences on this topic.
