QUOTE(PBC914 @ Apr 9 2012, 02:46 PM)
Help-When I put the turn signal switch together on the roll pins and hook up the wires in the back, and then turn the signal, a fuse pops (#9 fuse).
When I take the pieces apart, but still have them hooked up to the wires, the turn signals function, no fuse issues.
Is there a roll pin that is touching something it shouldn't?
Anyone else run into this issue?
Having exact same issue. Tonight I'm gonna try just isolating all metal to metal possibilities with elec tape and will report back. My suspicion on my issue is that a contact point on the right side of the switch assembly is touching the screws that hold the ignition key assembly housing together. From the looks of it a less than average electrician got hold of my car at some point.
