This weekend my '74 1.8, single two barrel webber with pertonics, had what I think was an infrequent miss. Heard a couple little pops, not shore if it came from carb or exhaust, and not very loud, but the engine did stumble and then cleared and ran normal, It starts and seems to idel OK, runs great and no loss of power that I can tell.
I started pulling plug wires off, while idelling, RPM drops when #1, 2 or 3 are pulled but no change in RPM when I pulled the wire off #4? I changed the #4 plug, which looked clean and same as the other plugs as far as color, and restarted the engine. Runs the same and when I pulled the wire off no drop in RPM. Wire will spark when held near the tin so I 'm sure I'm getting spark.
So, is this normal for #4, or is it a fuel sending problem or something else? I bought the car in September and I'm thinking could it be possible I've been running on three cyclinders? Doubt that but who knows.
