nine14cats
Oct 2 2004, 10:15 PM
Working on the 3.6 today getting it ready for it's new home.
Anyone know what tool to use to remove the pulley on the crank?
Does anyone know the part number?
Check the pic out....
Thanks,
Bill P.
McMark
Oct 2 2004, 10:19 PM
I've never done it, but looks like there's threads on either side for a steering wheel puller type deal.
Trekkor
Oct 2 2004, 10:27 PM
You may be able to find a three jaw puller that will fit over the pulley.
You can rent them.
KT
nine14cats
Oct 2 2004, 10:35 PM
Actually,
I need the wrench/tool that holds the pulley from moving while I remove the bolt that holds the pulley...
I've got several bearing pullers that I can use.
I didn't ask the right question...let me try to fix the thread and the question.
McMark
Oct 2 2004, 10:38 PM
Well in keeping with the tradition of knowledge-less answers, how about this... BF impact gun?
skline
Oct 2 2004, 10:40 PM
That is what I would use, an impact gun like you would use for wheel lug nuts. Works like a charm.
nine14cats
Oct 2 2004, 10:42 PM
I have an impact gun. How do I hold the crank from turning over?..that's the problem I have right now....
Bill P.
Trekkor
Oct 2 2004, 10:52 PM
Likely, the gun will use sharp quick blows that will have the bolt off before the pulley will turn.
KT
iiibdsiil
Oct 2 2004, 10:58 PM
Sometimes the lower quality guns won't do it. Not enough bang usually. The Snap-On and IR ones do though. You can try just keeping the impact going for longer, sometimes it takes a little bit. Maybe you can stop the crank from the back of the motor? Screwdriver in the flywheel?
Trekkor
Oct 2 2004, 10:59 PM
So, I guess you might need a flywheel lock?
Show us a pic of the back of the motor.
KT
nine14cats
Oct 3 2004, 12:16 AM
I have 2 flywheel locks...one of them is specifically for the engine....and the engine stand...and they don't fit for some reason. I could try the screwdriver trick...but it doesn't sound "clean".....
I'll try the impact gun tomorrow.
Thanks,
Bill P.
