nine14cats
Oct 2 2004, 10:38 PM
I asked the wrong question before....
What tool holds the crank pulley from moving while I loosen the pulley bolt?
Thanks,
Bill P.
nine14cats
Oct 3 2004, 12:58 AM
It's been said to try an impact wrench. I'll try that tomorrow.
Any other ideas or someone know the wrench I'm looking for. I have the wrench for my former engine, a 74 2.7 litre, but it doesn't work with the 993.
Thanks,
Bill P.
Brando
Oct 3 2004, 02:31 AM
there's a special wrench that you use, it goes on the top fan-part of the alternator. it's like a C-Shaped opening with two pins that fit into the holes on the front. you then take the alternator bolt off with the shims behind it. Replace the belt, and install the new one.
Steve
Oct 3 2004, 08:13 PM
I used a flywheel lock.
It slides over one of the trans studs and locks into the starter ring teeth.
Steve
East coaster
Oct 3 2004, 08:17 PM
Air wrench worked fine for mine. Is that going into a 914???
