Thank's for the earlier tip; the swithch had to be replaced. However, I still have a problem.
The e-brake light comes on with a buzzer sound and not blinking, just a steady light.
The emergency flasher light only comes on and flashes when the ebrake is on. Otherwise, with ebrake off, the eflasher does not work.
Here is what I did; replaced the flittle black flasher relay; replaced the ebrake switch. I see the back of the ebrake bulb has two grounds, I suspect one is for the ebrake and the other for the eflasher. I'm wondering if one of those wires got routed to the wrong place when the car was disassembled for restoration.
Can you tell me where the two ground wires should end up' or am I on the wrong track. I looked at the Haynes wire diagram, couldn't understand it, so I'm checking again with those with experience.
Any help will be greatly appreciated.
