QUOTE(r_towle @ Apr 10 2012, 06:33 PM)
Just flew in from Denver....boy are my arms tired...
Best way to fix that crack is to stop drill a hole completely through the section just slightly ahead of where the cracks stops. The diameter should be at least 1 .5 to 2x the metal thickness.
Bevel the crack slightly to form a groove centerline of the crack at least 1x the metal thickness down to at least 85% of the metal thickness in depth.
Begin welding the hole up first as a rosette...then finish the weld moving up towards the ball joint or edge of the part. If you weld the other way you'll just induce more stress into the part.
Bad part design when it was formed with the hard tool in the corner...however I'm sure them German Engineers never figured the part would be cycled for 40 years.
Now my arms and head are tired. My two cents.
