I put this gauge together from an old one, and spare tank module. There are no graphics on this gauge, and it has the center like an early gauge.
The pressure gauge/sender was used on my old 1.7, so I'm sure the sender is correct to the module. This is a single pole sender, so the idiot light is not used.
The temp gauge module was used with my 1.7, and the sender was in the Red car when it sold, so it doesn't have a sender to go with it.
I'm including the taco plate and small gaskets, and an oil sender mount the Cap'n & I made a while back (this bolts to the front of the fan housing).
The gas tank module came out of a spare gauge I had, so it is untested, but the gauge itself looked nice.
What you will need: The large rubber seal for the taco plate, and the metal gasket for the temp sender.
I'm including a braided hose to use instead of the grease gun hose.
I'm not totally thrilled with how this gauge came out, since I can't get the idiot light gels to line up perfect with the face. There is also a scratch on the pressure module face. If it were me, I'd take the time to paint the outer surround, but I ran it for years with just black marking pen touchups.
SOLD!
