QUOTE(Elliot Cannon @ Apr 12 2012, 09:16 AM)
I painted my trans. black to help keep it cool. Black dissipates heat. Isn't that why radiators are painted black? Many aircooled motorcycle engines are painted or otherwise made black. Why would powder coationg keep the heat in rather than transfer it out to the cooling air?
Did the overheating happen all of a sudden?
was it running fine before?
When was the last valve adjustment and tune-up (timing set, float level checked)?
is the idle steady?
Also check to make sure your vacuum advance is working and not stuck.
