1st symptom is car never seemed to run right. 2nd was tach started flipping out (very erratic needle. 3rd is funny sound from distributor (whining). 4th timing very difficult to set as the marks walked around (actually jumped around).
Pulled cap set dwell it jumped all over too on the meter. (crap) So I pulled the rotor again and wiggled the shaft slightly side to side but tons up and down.
Pulled distibutor and this is where it gets scary, I took the thing apart. shimmed up the slop cleaned up the grunge inside. Put it back together and the car runs
Able to get the timing to settle down @ the 7degree mark. but damn thing still jumps all over when advancing to the 27 degree. Dwell is now rock solid 45 degrees.
Dumb question and didn't try it last night do I need to take off the vaccum lines to set 27 degrees BTDC.
