QUOTE(IanStott @ Oct 5 2004, 10:38 PM)
The accelerator pedal is just flopping around, what parts do I need to repair this and where do I get them?
Thanks.
I've heard that the 914 pedal is NLA... but the 911 part is exactly the same. On the other hand, you can get a set of spiffy stainless pedals for about the same price. All depends how concours you want to be. I have a set in my duffle bag that I'm waiting to install.
I agree that if you're going to dive into that area... do it right. Pull the carpet, clean/POR-15 the area, rebuild the pedal cluster if need be (about an hour of work in itself).
If you're going to replace the cable... tie a piece of string to the pedal end before you drag it out the back. then use the same piece of string to pull the new one into place... as a guide so you don't tangle/twist them up.
hope this helps,
Rusty
