QUOTE(type47 @ Apr 17 2012, 07:14 PM)
... but the best thing to do is find the one with the body in the best condition, as Spoke pointed out, rust is the biggest enemy of the 914. You can always build up an engine (since you are a 911 defector, you will be seeking more power very shortly) and a 2 L can be built on a 1.7 or 1.8 case (cranks are different, heads are different, tin, ...). So, if you find a 1.7 with a good body, it might be more desireable than a 2L with a rusty body.
Second that. The motor work is easy, the rust repair can be quite extensive.
