KaptKaos
Apr 18 2012, 08:29 PM
I am about to go through a carb tune process with an LM2 AF meter, which should be fun.
However, I am just trying to set timing, idle and best lean idle with what I currently have and I continue to get pops in the exhaust at idle. I am hopeful that I will be able to tune that out, but I am wondering what would generally be considered the cause of those pops?
I have tightened all of my intakes, and exhausts. I don't think that I have any leaks. Tests with starter fluid don't yield any rise in rpm.
Is it running rich or lean at this point? Any help would be appreciated.
TIA
Rand
Apr 18 2012, 08:32 PM
If popping is in exhaust I wouldn't think lean, and I wouldn't think intake leaks. Sure makes me think exhaust leak, but sounds like you've checked that. Typically lean pops out carbs, rich out exhaust.
How's the spark? Yellow, or nice fat blue?
Mr. 5150
Apr 18 2012, 09:02 PM
I would be looking at timing lean can causing pre-det, rich is cold unless super rich like smell gas on dip stick rich not going to pop out the exhaust. Could be a floating valve?
dlestep
Apr 18 2012, 09:28 PM
Describe popping; what, where, when;
Does it sound like a gnat fart or a smooth bore report ?
What happens at 3500 in 3rd at throttle lift run-on ?
Does it go away at part throttle ?
Could be Fuel ( as in bad fuel delivery ); (crap in tank or fuel lines);
Could be incorrect jetting at your altitude; ( coupled with high idle )
Could be Air leak at base of carburator or manifold; vacuum leak;
Could be incorrect adjustment on crossbar linkage; (pre-loading one carb)
Could be Air being pulled into the exhaust;
Could be a crappy distributor;
Could be bad valve(s); valve guides, ( valve not seating properly );
Could be incorrect timing;
Could be incorrect valve adjustment;
Could be weak or broken valve spring;
You didn't mention what kind of induction (carburator(s) you're using, nor do you mention what kind of ignition system. You didn't mention what kind of exhaust
you are running ( dia, etc ).
All play a part in that gremlin.
KaptKaos
Apr 18 2012, 09:50 PM
QUOTE(dlestep @ Apr 18 2012, 08:28 PM)
Describe popping; what, where, when; at idle and part throttle. gone at WOT
Does it sound like a gnat fart or a smooth bore report ? Reasonably loud gnat fart, but not a bang like out of the tail pipe. Happening within the HEs I think.
What happens at 3500 in 3rd at throttle lift run-on ? Not running it right now to know
Does it go away at part throttle ? Nope
Could be Fuel ( as in bad fuel delivery ); (crap in tank or fuel lines); Checked and clean
Could be incorrect jetting at your altitude; ( coupled with high idle ) Certainly Possible. 50 idles at Sea Level
Could be Air leak at base of carburator or manifold; vacuum leak; Carbs, and all locations tightened and checked
Could be incorrect adjustment on crossbar linkage; (pre-loading one carb) Pretty sure I am good here, since it happens when the X-bar is disconnected
Could be Air being pulled into the exhaust; Possible, I will check stock HEs again, but pretty sure they're good
Could be a crappy distributor; New SVDA with Pertronix
Could be bad valve(s); valve guides, ( valve not seating properly ); Heads taken to shop less than 500 miles ago. Exhaust seats done.
Could be incorrect timing; VERY LIKELY
Could be incorrect valve adjustment; Just did adjustment. Had some loose ones.
Could be weak or broken valve spring; Not likely, as recently been to machinist
you are running ( dia, etc ). Weber 40 IDF, SVDA with Pertronix and Bosch Blue Coil, Stock HEs with Sebring Muffler.
Thanks for your input. Making sure I am on the right road.
rhodyguy
Apr 19 2012, 07:27 AM
you could have an air by-pass screw that needs to be addressed. as your engine pops at idle even with the linkage unattached, check the flow on each carb barrel with whatever type of uni-syn you are using. a distinct difference or more fluctuation between one reading and the others should help pin down the issue or at least eliminate one cause.
k
KaptKaos
Apr 19 2012, 12:05 PM
QUOTE(rhodyguy @ Apr 19 2012, 06:27 AM)
k
Carbs are synced fairly well. No fluctuations and all pulling the same on the snail. Will double check though. Thanks for the input.
mrbubblehead
Apr 19 2012, 12:58 PM
do you have your choke plungers pinned down? maybe fuel is dripping from them. does your a/f read rich at idle?
KaptKaos
Apr 19 2012, 01:58 PM
QUOTE(mrbubblehead @ Apr 19 2012, 11:58 AM)
Plungers removed and plugged with purpose built slugs from European in Hawthorne. I think those are taken care of.
I will actually have some time this weekend to look at the motor. Should be fun.
mrbubblehead
Apr 19 2012, 02:15 PM
QUOTE(KaptKaos @ Apr 19 2012, 12:58 PM)
are you able to isolate it to a specific cylinder?
KaptKaos
Apr 30 2012, 11:02 PM
So this weekend I had a few hours and I was able to get out there and take another look-see.
I jacked up the rear, stuck her in 5th and rotated the engine. I took off the dizzy cap, and looked for the timing marks on both the flywheel and the fan. Both came up when the rotor was pointing to where #1 plugs into the cap.
Hmm... good I guess, but doesn't help me explain my rough running and crappy timing. Let alone the popping in the exhaust.
So I start to put everything back together, and I go to put the cap back on the dizzy, and it's just not locking into place. I flip it over and discover the notch is on the wrong side.
How the heck I did that and didn't notice is beyond me. I have had dizzys on and off motors hundreds of times. So I rotate her 'round and button everything back up and most of the popping is gone. I had tweaked the timing before I stopped last time, so I am sure it's still off, but it idled solid.
That cap must have been wiggling like a bobble-head doll, throwing my timing and spark all out of whack.
Such a damn rookie mistake. Repeating it here so others don't make the same mistake.
Anyway, was about to start over with carb sync and timing, when the misses told me that the washing machine took a crap. Oh well.....
mrbubblehead
Apr 30 2012, 11:51 PM
nice find kapt. glad it was a simple fix...
ThePaintedMan
May 2 2012, 09:48 PM
Hey Kaos,
I have a similar setup on a 1.7 and I've having similar problems. However, its not the cap. The car pops at idle and runs like CRAP at 1/3 throttle. Seems to clear up between 2/3 and full throttle. Something tells me I didn't put the SVDA in right, or the plug wires are wrong. Would you be willing to take a picture of the SVDA in place and the location of each plug wire? Thanks!
KaptKaos
May 2 2012, 10:59 PM
QUOTE(ThePaintedMan @ May 2 2012, 08:48 PM)
Hey Kaos,
I can, but not likely until tomorrow. However, I can describe it to you to see if that helps in the mean time.
For reference, 12 o'clock on the dizzy would be straight towards the front of the car.
I had to rotate my SVDA dizzy about 90 degrees because the vacuum canister would hit the tin. So on a 009 or 050, #1 would be at about 11 o'clock, but with the SVDA #1 is now at about 8 o'clock. #4 sits at 11 o'clock and so on.
I hope that helps and/or makes sense.
I can snap a pic tomorrow. I think I should have some time.
KaptKaos
May 15 2012, 12:30 AM
Update: I think my timing light is shot. Used one from my autoshop class and was able to get the timing set off of the flywheel, at least a little more accurately. Of course, I had a collapsed valve cover gasket, so it was spitting oil, but I digress....
Tomorrow I hope to do some more, and get set to best lean idle and see how it goes from there.
KaptKaos
May 20 2012, 12:06 PM
adjusted the timing off of the fly wheel. Much of the popping is gone and things are smoother. There is still some there from over run.
it bogs really badly off idle. I need to rev a bunch to get underway. Can't be good for the clutch. Tips?
I have a procedure from Mr.bubblehed to tune the carbs well, haven't gotten to that point yet. Just want to get things to a smoother state first. Tia
mrbubblehead
May 20 2012, 02:15 PM
QUOTE(KaptKaos @ May 20 2012, 11:06 AM)
hey kapt, do you have too much accelerator pump squirt? did you balance with the bleed screws? then sync both carbs together? then reset your mixture screws to BLI? then recheck everything.....
KaptKaos
May 20 2012, 05:42 PM
QUOTE(mrbubblehead @ May 20 2012, 01:15 PM)
Carbs are synced with the air bypass adjusted as discussed.
At BLI right now, but bogs on start off.
I haven't touched the accl pump nuts. should I back those off a bunch?
mrbubblehead
May 20 2012, 09:33 PM
QUOTE(KaptKaos @ May 20 2012, 04:42 PM)
you could try it.... whar size are your venturies?
KaptKaos
May 20 2012, 09:56 PM
QUOTE(mrbubblehead @ May 20 2012, 08:33 PM)
28 iirc. I need to check to confirm, but I am 90% sure.
mrbubblehead
May 21 2012, 06:27 PM
QUOTE(KaptKaos @ May 20 2012, 08:56 PM)
hmmm..... those should give you plenty of velocity. im at a loss... for sure timing is correct? 28 degrees full advance? what kind of fuel pump are you using? regulator? are you using a fuel pressure gauge? should be about 2.5 psi....
ohhh what did you set your floats to? up position and down position.
does the bog feel like a rich condition or lean condition? or is it hard to tell?
fuel filter clean?
how does it rev with no load? like sitting in the driveway in neutral.
we'll get to the bottom of it
KaptKaos
May 21 2012, 08:14 PM
QUOTE(mrbubblehead @ May 21 2012, 05:27 PM)
Hmm.... Let me get back to you on this one..... I think I am at 32 degrees, which would be too much.
