ENGINE: 2.5 Porsche motor, fully rebuilt head, tanked, decked and polished, new valves, seats cut, guides replaced, caps, OEM (Vic-Rein) performance gasket set, compression at higher end of factory spec, even all cylinders, new thermostat, fresh antifreeze, hoses, filters, new plugs, rotor, distributor cap and wires. Intake manifold polished and ported, rebuilt throttle body with new idle switch. ECU/DME Computer replaced with new rebuilt, transferable 5 year warrentee, all electric connections cleaned and checked.
BELTS: New timing belt, balance belt set and tensioned, new alternator/air con belt, new power steering belt
FUEL INJECTION SYSTEM: Fully rebuilt, injectors resealed, cleaned and set, fuel regulator, dampener and filter, fuel pump, new idle control valve
PREVIOUS OWNER"S Recent repairs include all 4 brakes, full high flow exhaust with cat and muffler, new clutch, all appear to be professionally done and correct
BODY, (BLACK): rust free, normal rock chipped and minor scratches. Car could be close to a show car with a decent paint job, but as is, is a presentable driver.
INTERIOR (BLACK): Original Porsche script in nice condition, no known tears in any seats, rear left side seat belt receiver is broken, dash has normal cracks.
TIRES: New about 1000 miles, tread like new
Porsche 924 912 914 944 928
E-mails without reply telephone numbers or "Porsche 924" in the message text will be deleted without response due to too many scam emails on craiglist
- it's NOT ok to contact this poster with services or other commercial interests
View the full article
THIS IS NOT A 914WORLD AD!
Do not reply to this thread! No one is listening!
Click on the "View the full article" link above to go to the actual Ad!
