As I have gone to a 930 trans, the following is available for a standard 901 trans:
Renegade adapter and clutch kit- (light street use for very few miles…OK, a few burn outs)
Adapter SBC ’86 up one piece rear seal(used)
-Hardware to attach this to the sbc block.
Note: I don't believe this will fit the LS series of engines based on Kennedy having a different p/n for the flywheel for 1985 and under engines, 86 and up engines (which I have) and the LS motors.
Flywheel (used) One "hot spot", but I would not resurface it for this reason.
-Hardware to attach this to your sbc crankshaft.
9” Kevlar clutch (used)
Pressure plate (used)
T/O bearing (used)
Pilot bearing assembly (new)
Dust shield (used)
$350 shipped CONUS
I do not have the following parts: Water fittings, water pump assembly, motor bar, radiator, harmonic balancer and spacer. You will have to source these elsewhere.
Sorry for the poor quality pictures. The Nikon was borrowed by someone at the office and not yet returned.
