QUOTE(CCLAY @ Oct 7 2004, 10:29 PM)
But.....he already does have 'cut up' door panels.
The door a terrible environment for speakers??? Properly prepared, and since he does already have holes cut in, doors are a PERFECT place for speakers. The bass response from the door enclosure wll blow away anything you could ever get from the kick panels, ergo the reason for the sub unit that is sold with Morphenspectra stuff.
Rob, if you really want to use 4 speakers, you should consider doing separates and using the door panels as bass enclosures and the kickpanels for mid/hi range speakers.
Anything that goes into that kick panel should be crossed at no less than 150 MHz. That's why in the Morphenspectra kit the sub enclosure goes in the center of the car interior. The worst thing I think you could do is put 4 identical speakers in there and expect it to sound good.
Chris
Reasons I don't like door speakers:
1. Water gets back there, no matter how good your seals are
2. Way too many things in a door to rattle
3. The enclosed volume is to large for the size of speaker you can fit
4. You'll never get the enclosed volume sealed well
Of course this is just my opinion, you can do watever you like.
