side shift conversion parts only, shift rods, shifter, engine bar, tail cover, shift console, rods and forks
complete kit $425.00 or $1200.00 installed
shift linkage bushing replacement $199.99
fuel injection flushed/high preasure for maximum flow $179.00
recalibration of your mps as per spec to your ecu $150.00
exhuast leak ?
reseal exhuast for $135.00
EXAMPLE OF OPTIONS-
FIRST/REVERSE GEAR REPAIR- NEW SLIDER, SYNCHRO RING, SYNCHRO HUB $975.00
complete synchro hub (dogteeth) and synchroband replacement with all new parts $1750,00
COMPLETE TRANSMISSION REBUILD WITH ALL NEW BEARINGS, SYNCHROS, HUBS, AND SEALS $3752.00
COMPLETE REBUILD WITH BILLIT ALUMINUM INTERMEDIATE PLATE $4352.00
Realising not everyone can afford to rebuild their transmission with all new parts, i offer used parts for a fraction of the price of new. all used parts pass spec's to provide you with an afordable option. quantity depends on level of used stock on hand.
buying a transmission, but dont know condition of internals, swing it by and for $75.00 ill open it up and check it for you. you can find used transmissions for between $200-500.00 but after 40 years of use, time is not on your side......
also high performance engines, stock rebuilds 1.7, 1.8, 2.0 injection or carb built engine's available....
L-jet and D-jet specialists....dont toss your injection...i can help....mobile service available to all so california locations. from thousand oaks to san diego, from the pacific to tuscon arizona.....mobile mechanic specializing in porsche 914 only.
rust? dont scrap your car, i repair rust and collision damage at a fraction of a body shop and stock most sheetmetal that is real porsche material.
let me know what you have and most the time i can give you a quote over the phone or email. stock color code repaint, or custom... we do it all...
951-907-0362
- it's NOT ok to contact this poster with services or other commercial interests
View the full article
THIS IS NOT A 914WORLD AD!
Do not reply to this thread! No one is listening!
Click on the "View the full article" link above to go to the actual Ad!
