Rhodes71/914
Oct 8 2004, 12:20 PM
So I was under the front end last night removing the nuts on the brake MC and I noticed a hole with threads showing. A bolt is missing on both sides. Can someone tell me what goes here and why they would both be gone.
sr
bondo
Oct 8 2004, 12:22 PM
Those two bolts also hold the belly pan on (a piece of sheet metal that covers the master cylinder/steering rack area). Not sure what size they are. There are two more smaller bolts that also hold the cover on that are also undoubtedly missing.
Rhodes71/914
Oct 8 2004, 12:26 PM
QUOTE(bondo @ Oct 8 2004, 10:22 AM)
Thanks, looks like I need to get that belly pan peice.
URY914
Oct 8 2004, 12:27 PM
Actually you need those bolts to hold more than just the pan. They also secure the steering rack to the car.
You need these. It's a shollow hole (no jokes please) so you need a short bolt. But find them and install them.
Paul
type47
Oct 8 2004, 12:30 PM
it's about a 15mm bolt or what ever the bolt is that you use a 19mm socket for. while you're reinstalling the skid plate, you need 2 13mm bolts for the rear holes of the skid plate.
Cap'n Krusty
Oct 8 2004, 12:35 PM
10mm x1.5 thread pitch x 30mm length. You'll also need a flat washer and a lock washer. The Cap'n
seanery
Oct 8 2004, 12:50 PM
the lock washer is the wavey type not the split type, yes?
Rhodes71/914
Oct 8 2004, 12:53 PM
Anyone have a skid plate/bell pan/cover that they want to sell? I didn't get one with the car.
seanery
Oct 8 2004, 12:54 PM
Who's closer to you Morphenspectra or Boxstr?
I bet both of those guys have them.
Aaron Cox
QUOTE(Rhodes71/914 @ Oct 8 2004, 11:53 AM)
i might, if i dont, i gave it to drifter jay.
Cap'n Krusty
Oct 8 2004, 12:56 PM
QUOTE(seanery @ Oct 8 2004, 10:50 AM)
Porsche uses the split type "steel-to-steel." The Cap'n
Rhodes71/914
QUOTE(seanery @ Oct 8 2004, 10:54 AM)
I think they are both in the Portland area, about 3 hours away from me.
Oct 8 2004, 01:11 PM
you need 'em!
your steering rack will flex like crazy without them. not good.
ask me how i know ...
Andy
Red-Beard
Oct 8 2004, 09:08 PM
QUOTE(Cap'n Krusty @ Oct 8 2004, 10:35 AM)
What he said.
I bought a metric kit from a great hardware store. It has eveything from 4mm to 10mm, nuts, washers, bolts, lock washers. Good for these kind of problems.
Eddie Williams
Oct 8 2004, 10:30 PM
isn't the steering rack attached to the top of the crossmember? those look like the rear crossmember to body mounts.
Oct 9 2004, 12:18 AM
QUOTE(Eddie Williams @ Oct 8 2004, 09:30 PM)
same difference ... but you're right. crossmember. still flexing like crazy without the rear bolts tho ...
Andy
URY914
Oct 9 2004, 04:23 AM
Read my lips...
Put the bolts in.
watsonrx13
Oct 9 2004, 10:03 AM
Here's a shot of the bolt before removal. This is the rear control arm support bracket, you need to fix this
NOW!!! before you do any more driving.
Rhodes71/914
Oct 9 2004, 10:09 AM
I have got the bolt and yes they will go in before I do any more driving. Pedal cluster is out now and I ned to do some break work so I couldn't drive it if I wanted to. Makes me wander why they are gone in the first place.
Thanks for the help.
Now back to pounding on my pedal cluster damn it.
Oct 9 2004, 04:26 PM
QUOTE(Rhodes71/914 @ Oct 9 2004, 09:09 AM)
someone removed the pan to work under there and didn't bother to put it back on ...
i've seen this more than once,
Andy
