Britain Smith
Oct 9 2004, 12:10 AM
I found this on the bird board, this guys has a 911 motor with custom valve covers to accept a coil on plug set-up. Brad and I thought about this for my motor, but figure that the Electromotive set-up would be good. What do you think guys...adapable to a type-4 engine with the Kit Carlson FI?
-Britain
Brad Roberts
Oct 9 2004, 12:23 AM
I *thought* the last air cooled engines had COP.
B
Mike9142.0
Oct 9 2004, 01:23 AM
The wet engine was the first for COP in 98.
TimT
Oct 9 2004, 06:02 AM
I was going to do coil-on-plug on my 911, I decided against it because machining the valve cover was just another obstacle preventing me from getting the car on the track, so I went with coil packs.
It can be done if your timeframe allow why not try it? makes for a really tidy wiring harness , and no plug wires.
I think I found that the ignitor is built into the coil, so if the kit carlson controls coil dwell then you could be good to go.
DNHunt
Oct 9 2004, 06:32 AM
Kit's system is wasted spark so it's gonna fire the coil twice in each 4 stoke cycle. That might be a problem at high RPMs
Dave
machina
Oct 9 2004, 07:57 AM
Man that motor looks expensive.
