skline
Oct 9 2004, 10:04 AM
I got these new to replace the one that was missing and the other one that looks older than me. Trouble is, how do you get them in? I tried grease, WD 40 and heating them up to soften them with no luck. Anyone out there with any other suggestions?
skline
Oct 9 2004, 10:33 AM
Also, once I get them into the dog bone holders, is there a trick to getting them back on the bolts at the base of the shocks?? What a pain these are. I am hoping they are worth it.
Bleyseng
Oct 9 2004, 10:36 AM
I used a large C clamp to force them into the dog bones and then used a large pry bar to attach them to the shock bolt. They snap in when you force them
Rear bar is undone now thou....
Geoff
bob174
Oct 9 2004, 10:42 AM
Big Pain in the Ass! Went through this summer before last. I ended up pressing them into the dog bones using a vise.
seanery
Oct 9 2004, 12:35 PM
Scott,
I just did these myself.
I put the drop link in the vise and push the cup in as far as I can, then using a largish regular screw driver I push the part that I couldn't get in by hand until it goes in the link. (don't do this by hand or you (like me) may end up with a large screwdriver sized hole in your hand.
Then I take it out of the vise and tap it in with my plastic hammer.
I haven't been able to figure out how to them on the shockmount yet. Tried a BFH and lotsa arm power and couldn't get it.
Cap'n Krusty
Oct 9 2004, 01:36 PM
I use a really big pair of channel lock pliers to squeeze them onto the ball ends. The Cap'n
JoeSharpOld
Oct 9 2004, 02:33 PM
Scott: I have 2 dog bones with new bushing in them. I'll trade you them for yours and the tin you said you might have. I'm going to the chicken coupe for lunch I'll stop by after that.
Joe
Series9
Oct 9 2004, 03:09 PM
C clamps. They are a bitch.
DuckRyder
Oct 9 2004, 03:10 PM
QUOTE(Cap'n Krusty @ Oct 9 2004, 03:36 PM)
Yep worked for me.
Soak em in hot water and use a vice to put them into the dog bone. It is a huge PITA.
Bruce Allert
Oct 9 2004, 04:33 PM
Put the dog bone on the bolt with a vise then install into the shock. Using a hair dryer on the remaining part along with channel locks and a wee bit of grease works quite easy.
......b
skline
Oct 9 2004, 05:46 PM
I want to extend a huge Thank you to Joe Sharp, he dropped off the dog bones with the bushings already installed, now I just need to try to press them on the sway bar and the shock bolt. I am sure I will get it sometime tonight. Thanks again Joe.
BMartin914
Oct 9 2004, 07:32 PM
Just did these last week.
Once you have the bushings in the link, we just used a really big C clamp and two hands to keep the dogbones straight while we pressed them on. Surprisingly easy, took about ten minutes with the right tools.
monkeywrench
Oct 10 2004, 08:40 AM
Using a C-clamp or a furnature clamp works really well for me. Just apply the pressure slowly.
type47fan
Oct 10 2004, 12:00 PM
Steady, even, patient pressure. If you have the car elevated, take off the road wheel and support the trailing arm to align the sway bar and shock mount to a neutral position. Then, ten minutes, tops.
Wayne (type47fan)
SLITS
Oct 10 2004, 12:10 PM
Vise, grease and socket to put them into the links
Big pair of channel locks to snap them onto the ball ends
No problem man!
Joe Ricard
Oct 10 2004, 06:00 PM
Vise to put them in the "dog bone"
2lb hammer to whack it on the shock bolt ball end. (one whack all done) Oh and levae them on the drive way for an hour in the Mississippi sun. Nice and soft.
Of course you are a sweaty mess any way you cut it.
I used to do the lay it in the sun trick for Nylon U-cup seals for hydraulic seals.
