Hey Kim, hey Mike, sorry, not ignoring you
Noise? Yes, some road noise will be transmitted from the suspesion to the car...how much, well, I'm sorta embarressed here, I've never been in a roller bearing equipuid car, or at least one that ran
The level should be just a tad more than the plastic bushings but not too much more, figure the plastic bushings will not "abosorb" much noise and will transmit the noise as well.
Brad? care to chime in?
Currently, these have all been installed on race cars...Yeamans is the closest "street" car that I know of, he has not complained once...JP, care to add to this?
911 or 914?? No difference at all..these are only good for 911's up to early '89's that use the steel a-arms(torsion bar cars)...in late '89 the 964 series 911's came out which have a completely different suspension. (I will take pictures today of my 964 suspension while I change the brake rotors)
The bearings will still work on 914's or 911's that have been
converted to coil-overs as well.
Now why do the bearings work so well?
For our application the bearings are "near-friction free".....notice "near"....nothing in this atmosphere is free from friction, but these are damn close....
The specs for the needle bearings themselves are tighter than any single component than your motor......the sleeves are 1.5000 +0/-.0005
the bearings are 1.5000 +0/-.0005...try finding a more precision part in your engine?
What this means is that the a-arms are located positivly and securly to the chassis.
Now to get back to why they work, hahaha
Comparisons:
Factory rubber....these would work okay if you had
zero up and down suspension movement since the best thing they would offer you is some isolation from road noise.
Why don't they work as a suspenion component? The problem is that the rubber is "gripping" the bar at both ends not allowing the a-arm to freely rotate
the a-arm should pivot smoothly like a hinge on your office or bedroom door. But the rubber is so tight on the a-arm shaft that without tremendous force, the a-arm cannot rotate while being held so tigthly.
Plastic bushings:
These are a step up from the rubber
if installed correctly. The proper method to install the plastic is first press them into the factory housings and ream the inside diameter to match the OD of the a-arm shaft so that the interference fit is minimal. With the plastic bushings, grease can used to help the a-arm rotate in the bushings.
Now one part of the bushings we have not discussed is the "flange" of the plastic bushing, this too needs to be addressed and lubricated as well since the flange of the bushing and the flange of the a-arm also come into contact. In fact during hard braking, this contact surface is put to the test even further (on the rear set of a-arm bushings) since the braking action is causing the two flanges to bear even more of a load than normal driving.
Now back to the office door....if one was to excert pressure on the top of the door, it will be harder to rotate for a couple of reasons, one is that you are putting stress on the hinge pins and the hinge itself and second would be that the surface of the hinges would be fighting each other.
With the Needle Bearings, the friction on the flanges is reduced with the use of needle bearing Thrust Washers.
I know none of this makes sense and I probebly confused you more, I'll have to make up some drawings or diagrams since I have a hard time writing this tech stuff, i know what I want to say, i just don't know how to say it
